Radio decoding
sleepy0905
Radio decoding
Post by sleepy0905 »
Hi does anyone here know of a friend or can do it themselves I have a Philips radio that was given to me by our good friend Billy but it needs decoding and i have been quoted £20 now i dont really want to pay that I am trying to download the code calculator of limewire as I already have a lot of coding software but none for Philips. :D
Doz
Post by Doz »
I thought the code for philips was in an e2prom?
Used to do it years ago, but it needed a laptop and a probe that you attached to the radio (over said e2prom)
I think grundig's can be decoded via the serial number ...
Doz
2007 Citroen C1 (it's not a real Citroen)(With a complete set of wheel trims)
2006 C4 1.6VTR+ (Alloys no wheel trims)
1982 Mini HL (No wheel trims, no wheels)
1993 Kawasaki GPZ500
cacaolat
Post by cacaolat »
Hi, I had the same problem, there were many places charging 20 quid, but eventually I found a website with a forum were you give in the serial number and someone tells you the correct code for free. I will try to remember the address of that website....I will let you know
cacaolat
Post by cacaolat »
sorry I should have mentioned my radio is from Blaupunkt though....
sleepy0905
No problem if you can find the forum i will have a look i have found one forum already but any others will be very usefull.
Sleepy - I think the answer for the Philips is quite simple and has I'm sure been given on the Frenchcarforum a number of times - as I think there is some confusion in getting the thing to take the code or something.
Quick search gives the following link - but if that's no good I suggest you search there as you will know what you have.
http://radiocode.proboards6.com/index.cgi
sleepy0905
Many thanks that look a good forum will check it out later. 8)
x 103
did you get it sorted yet? i have a decoding program that should be able to do it for you, will email next time im on the big comp (rather ill at the moment so in bed ont' laptop).
sleepy0905
Not yet vanny, give me a shout when you are better and i will give you all the details if you can do it then that will be excellent.
Me and the missus say GET WELL SOON :roll:
