Phone number removed. BXClub Mod.
tzd gearbox
donna
tzd gearbox
wanted tzd gearbox for my 1769cc turbo hurricane as i have made a mess of my old one thanks gaz
- Keeper of the site Goat
You have in fact damaged the differential output shaft and scored the housing - which may be sound on otherwise broken Turbo-diesel gearboxes.
The TD has a unique set of ratios - and final drive ratios. I think you'll find the broken bit on yours attaches to the sun wheel in the differential unit - and it may be possible to change this alone. This however may need to be set up and shimmed to avoid noise - and I don't think the instructions are in Haynes.
