Bonded windscreens
sleepy0905
Bonded windscreens
Well i have just bought the correct equipment for removing bonded screens as I am going to get a new screen for the AX from the scrappers after it sustained a 4" crack on the N/S Lower edge so does anyone have any experience for doing bonded screens I have enquired about the required adhesive and i can either get the one that uses a primer for the body and a primer for the glass and comes as a kit with all the primers and swabs + Adhesive or the other product which is used aparently is called Tigerseal and is made by U-Pol.
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
do you know what 'grade' of sikaflex ken? There seems to be about 4000 different variations for jobs from sticking floor board down to filling gaps between floor board and sticking body kits on, last tube i bought was white and didnt finish with that rubber feel that the windowbond/body kit glue seems to have.
Brian
sleepy0905
Here are the tools i purchased the wire saw was off ebay for £2.50 and the draper tool was from Portland tools in Lincoln for £7.68 and replacement blades at £2.50.
I removed the screen from an old BX hatch i had today and i can say it is bloody hard work on the arms even with the correct tool but i couldnt of done it without it what you do is push the point of the right angle blade in to the sealer at one corner then you pull the blade along the sealer using the handle of the tool to steer and guide the blade and the T handle to pull like a goodun on and hey presto the sealer is cut and the screen is out without breaking it especially as i practised on a Splintex screen not a laminated so it was even more crusial to get it right as one wrong move and you have a thousand little cubes.
Brian
Thanks for the pics Sleepy...
I tried to remove a windscreen in the past as a challenge, from an old BX.
Started using a scalpel, this was too flimsy, I then sharpened up a length of an old hacksaw blade, and wraped some cloth around it as a handle, holding it tight against the glass, and cutting in one direction, progressed around 3/4 of the screed, then "crack"...
If I had a helper to gently apply pressure from the inside, I am sure it would have come out intact.
I have heard of other methods, for instance using a length of welding wire, with volts from a 12v battery applied to it, but never tried that method.
Best of luck using those tools..
sleepy0905
cauchoiskev
