I have got a good little ZX but it hasn't come without it's own problems and annoying little things. I had the car for about 4 months and the heater direction flap (ie floor, face or windscreen) stopped working. I have pulled the radio out and had a go at turning the lever on the ducting by hand and it all works fine. I think there is a problem with the flap "INSIDE" ..... I think this may require the removal of the dashboard to remove it all ..... but is there a way of being able to move this flap so that i can change the position of air flow. I want to redirect the air to the windscreen to stop the misting up. At present it is on the "face" position. If i can just get it to change I won't worry about trying to pull the dashboard out etc ... the other thing is... can the windscreen wiper "park" position be changed over to the "RIGHT" hand side???? and how can it be done??
cheers
