The Hydraulic Warning light briefly illuminated, same thing in exact same place on the return downhill leg occured, Yet nothing in between a distance of 260km.
Few Kms further it did light up again still going down hill but I had noticed the steering was feeling heavy, brakes less responsive and genrally harder suspension.
I dare not put it into high to check the level thru fear of blasting a weak octopus pipe in to leaking. So chucked in third litre of LHM. LHM is as rare as hens teeth around were I live.
There is a drip of fluid on both the acumilator and Sphere housings. Yet I cant see a leak from above and the Air con pipes obstrusct good view from below.
No other visible leaks any where. Starnge thing is no drips on garage flow either
Anyone got a idea of a cure or possible caus of the unknown leakage?
