I despair.
tom
- Citroen Sorceror
I despair.
Further down the Forum, somebody is selling a BX with a faulty blower.
Despite all the correspondence and advice given on this topic which is now a very well trodden path, a regular has posted "Try hitting it with a rubber mallet."
This then is to be the legacy of the club and of the forum, that the contributors who have put many hundreds of hours into helping owners understand and diagnose the problems on their cars shall be supplanted by "Try hitting it with a rubber mallet"
Gee, thanks.
Gee, thanks.
- x 27
M
tom
- Citroen Sorceror
It works (or more correctly worked in the days of valves) with tellies for a very good reason.
Only certain people can be considered qualified to use any kind of hammer on a BX and then only when denied red or raw meat
which is the real reason why we've got Billy on a diet of Hungarian turkey twizzlers.
- x 27
Ah, thats ok then, cos I dont eat any meat at all, raw or otherwise!tom wrote: Only certain people can be considered qualified to use any kind of hammer on a BX and then only when denied red or raw meat
I actually find hammers an invaluable tool for BX fettling, although I'm disgusted at the thought of using a "Rubber" hammer. Wheres the risk in that? Much better off using a 14lb sledge!!
Chris G
mnde
- Meteor Man
I apologise as I am indeed the perpetrator of said advice.
Such advice was never intended to supplant the rich vein of advice on the matter offered on the forum.
Only, after all else failed, I tried giving the motor a smart tap with my mallet and it burst back in to life, case solved!!
My reasoning was to give the guy something quick and easy to try first, as he's trying to move the car on, as it worked for me. Not to encourage a "bash it first, ask questions later" methodology.
Perhaps I should butt out in future?
I know the feeling Tom - I've advocated repairing FDV's with a tap on the ball bearing non-return valve. I've had people complain it doesn't work when they've ground the ball using grinding paste, and one guy on the French Car Forum even tried drilling it to get a better seat! This of course ignores those who think that riveting it with many blows is better than the one recommended (produces multiple seats which overlap)
The practice is not my own invention in fact but pinched from the overhaul instructions for a Laycock overdrive. I used it on my Triumph Stag - where it was so successful the thing took 5 seconds to disengage! (May have had something to do with other components from the other unit I cannabilised)
- x 27
Barnsley BXer
- Keeper of the site Goat
mnde wrote:I apologise as I am indeed the perpetrator of said advice.
Like you say mate he was moving it on and it`s worked for you. I hit everything with hammers, sometimes it works, sometimes it doesn`t but it`s free and fun to find out!
Vauxhall apologist.
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Whats the problem with trying a bit of force anyway Tom? Its a motor with brushes, there is every chance of the brushes having simply stuck. Infact if it was any other motor i suspect that it would be first responce for most people to try and it does work on many motors including the starter motor!
While i accept that the bitron unit and dash mounted potentiometer are know for causing this fault, there not the only cause, and to think that every single bx will have the same exact problem when giving these symptoms is not exactly a good basis for fault finding! Infact the only time i have ever had problems with the fan was a corroded connector in the scuttle, no cause other than age (no pools of water etc) and very easy to diagnose!
THere is too often an attitude of some on here that there can only be one explanation for any given problem, and it's simply not that easy! I know for fact that i have had problems that no one else has had nor has anyone been able to diagnose, and i've been told many times that certain tasks simply can't be done.
mnde, your input is perfectly valid and a suitable responce to the problem, its a shame that people think they can persecute you for your input, dont be put off!
tim leech
- BX Digit man!
Banging, or at least tapping a brushed motor is a perfectly acceptable "first test", and can be quite revealing. If the motor bursts back in to life, there's a fairly good chance that the brushes are 99% used, and it really needs new ones. At least after the bash-test you have a working fan while you source some new brushes.
The only problem comes when this doesn't fix the problem, and someone then beats merry hell out of a perfectly serviceable motor, thus breaking it, when the fault was elsewhere.
