Is the ABS relay part of the main fuse box or is it located elsewhere ?.
I have an intermittent warning light fault. I goes through the self test routine and then goes out.....and can come on again at any time with no particular common factor. It has even reset itself while still driving without me having to restart the motor. I have checked for broken wires and cleaned the connections to the ABS unit to no avail.....I am now becoming p.....d off and soon I shall be completely p....d of if I cant sort out the problem !
Tim.
