Handbrake BX 16v
pinfold
Handbrake BX 16v
Post by pinfold »
The other day i pulled the handbrake, and nearly took it out through the sunroof, i assume because the cable has snapped.
Have phoned GSF, who will supply me a front section? for ten quid
Does anyone know about handbrakes and does this sound correct
Also is it easy to fit
Matt
BX GTI 16V 1991
XANTIA SDX 1996 ESTATE
Front section????
Theres only two cables, one for the left, and one for the right...
However, with the car in the air, or on ramps, then yeah, they are VERY easy to fit, no more than 30 mins start to finish to do both sides.
Once you're under the car it becomes VERY obvious where it all goes.
Chris G
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
could be low on pads too...them warning lights are shite! Best check to be sure!!
