HELP! battery light
simonbx17
HELP! battery light
Post by simonbx17 »
hi,
can anyone shed some light on the problem i have, when driving for about 30-40mins on the motorway, when i use the indicators the battery light comes on :shock: and the indicator relay buzzes and there is no indicators but hazards work fine! when i switch off the indicators the battery light goes out?
when i leave the car for 10 15 mins everything is fine and back to normal.
this happens at the end of a journey :?: :?:
:idea: would this be a relay issue or indicator stalk issue.
:roll: sorry topic in wrong place ca it be moved :roll:
Current.
Alternator not recharging battery sufficiently?
simonbx17
checked that
Post by simonbx17 »
checked that already and retightened my battery terminals i've never come across this before!
thanks
Current.
tom
Citroen Sorceror
x 38
Post by tom »
Buzzing indicator units are caused by a faulty hazard switch which can also cause the charge lamp to illuminate. (I have seen this before but memory failed me.)
simonbx17
thanks
Post by simonbx17 »
thanks i will investigate this and let you know. but if anyone has more ideas on this it will be much apprieciated.
cheers
Current.
sleepy0905
Post by sleepy0905 »
I would say hazard switch too had a similar problem on my mates bx.
simonbx17
thanks
Post by simonbx17 »
thanks guys i what i will do is change the relay and hazard switch cross my fingers and see if this sorts it. :)
phillip is that 16tgs from ebay? 8)
thanks again for your help.
:P
Current.
Re: thanks
simonbx17 wrote:phillip is that 16tgs from ebay? 8) :P
Well it's the one from here (I don't think it went on eBay): http://bxclub.co.uk/forum/viewtopic.php?t=4977
It's very nice, clean and very low mileage...
tom
Citroen Sorceror
x 38
Post by tom »
Don't bother changing the relay. It isn't that.
simonbx17
o.k
Post by simonbx17 »
of course it was that one on this site, well done for saving it and keeping it in the family as it were. :wink:
tom i will leave the relay alone then and just change the hazard switch and see what happens, thanks for your advice much appriecated :)
cheers
Current.
