Hi all, could anyone please tell me is a 1991-1992 BX Meteor supposed to have remote central locking ?
If so does anyone know where to get the plip and how much £ ?
Finally would the receiver and plip from an XM work ?
Remote locking.....
martin
Stewart (oily!)
The other give away for plip (remote) control is does the passenger door lock operate the electric locking system or just unlock that door. Strange but true - the plip uses that terminal on the controller!
You may be able to fit someone elses interface which has the advantage of coming with a pair of new plips. I think Maplins do one for about £50 - and you get an alarm as well.
http://www.maplin.co.uk/Module.aspx?Mod ... =&doy=6m10
- Keeper of the site Goat
It`s just remotely possible I may be able to help you. I still have a remote `plipper` from a 405 Peugot which I scrapped and it was working fine when the car got weighed in.
On the back of it just visible in red letters is the following information:
A000 284L then what looks like: CEPT LPD-D. It MIGHT be a Scrpion jobby as there does vaguely appear to be what looks like a picture of a scorpion on it.
The red light still flashes briefly when you press either of the two button on the unit. One button is red and the other is black-I would assume lock and unlock.
If you p.m me your name, address and postcode you`re more than welcome to it and if it doesn`t work just bin it. I`ll post it out to you as soon as I can, probably tomorrow afternoon.
Vauxhall apologist.
martin
Thanks for the replys.
Cavmad , upon removal of the sunroof motor panel i could not see any receiver so i dont think your 'plip' would work but thanks for your offer and keep hold of it anyway.
The car does seem to have some kind of alarm but no plips as there are sensors on the windscreen pillars (pos why the c/l does'nt work ?)
BTW all, i picked my BX Meteor yesterday evening
(this is the first time i have been at my PC !) and everything seems good/genuine so far but there are inevatably a few small issues with the car (just discovered c/l not working = boot always open = poss thieving scum !) plus the things i have already mentioned in my previous posts.
Hope to get some pics up as soon as i can ! You wont believe the interior condition !!!
No problem Martin. I suppose it`s possible that the alarm didn`t have a facility for locking the doors anyhow and it sounds like the central locking playing up on you car may be something fairly simple. Isn`t there some sort of solenoid for each door which works when you turn the key in the door locks? If so, and assuming you can locate the one for the boot, do you have a spare one you could try?
Vauxhall apologist.
Stewart (oily!)
martin
I have fixed the central locking !
Good job i checked the obvious place first before starting taking door panels off as it was just a fuse but why it has popped is a mystery ,poss to do with what i can make out to be an old ? Foxguard alarm ?
Also i have found that the interior lights dont work with the doors open but work when switched manually (strange,again alarm ?) and the 'lights on' buzzer doesnt seem to work although im sure i heard it once when starting the car with the lights on and door open .
That does seem strange! As I`m sure you know it`s only when the keys are out of the ignition that the lights on buzzer normally operates, though I suppose if they are only pushed in (as opposed turned to position 2 or 3) then the buzzer may still operate.martin wrote:I have fixed the central locking !
Also (and I`m not taking the p*ss I promise) have you tried putting the switch on the interior lights to a different position then opening and shutting the doors to see if they come on? I did it on mine just this morning and the easiest way is to have the door open whilst you move the switch until the light comes on. Then just close the door and if the light`s gone off you`ve cracked it.
Stating the bleeding obvious like I said but I`ve overlooked it many times in the past!
Vauxhall apologist.
I expect the switches in the door pillars which operate the interior lights have corroded - they all seem to after about 10 years. You may be able to clean them but new ones are less than a couple of pounds from GSF and places and so you may not think its worth the bother of messing with the old ones.
The lights on warning is operated from these switches - so won't work if the interior lights do not work automatically.
