ignition switch wanted, quite urgent?
Andy G
Post by Andy G »
the ignition switch on my newly aquired GTi has failed, in that the key end has broken from the key and there's no way I can retrieve it. So does anyone have a decent one I could buy?
Ian_Fearn
Post by Ian_Fearn »
Try these people if you want a new one £37.92.
http://www.aepdirect.com/citroen-part.aspx
Over and out from me
Andy G
Post by Andy G »
thanks, I've ordered one and it should be here in a few days, looks quite straight forward to fit.
Thought I'd go new on the basis if I got a used one I may end up in a similar situation a few months down the line.
Ian_Fearn
Post by Ian_Fearn »
Fairly simple to fit,
Remove the steering wheel and column shroud.
Then remove a tiny little bolt in the side of the ignition barrel. Withdraw the barrel and detach wiring which goes under the dash towards the centre console.
Nice easy clean job!
Andy G
Post by Andy G »
in the haynes it says you have to turn the key between position A & C to allow the spring release to be pushed in & that will allow the barrel to be removed. Mine won't move but I am ever hopeful it will be an easy job. Should be here tomorrow so thursday eve I'll be working in the rain no doubt!
Andy G
Post by Andy G »
well retrieved broken part of key, but still cannot get the spare to go into the barrel. Lots of wiggling and oil still no joy. Oh well there's always tomorrow!
