I’ve fitted new discs & pads up front and all is well apart from the handbrake that sticks on when I use it (offside wheel)
I pulled back the rubber cover to find a lot white corrosion =, I cleaned it out and sprayed In some
WD40 to try and loosen things up but it still sticks after I’ve released the lever
And I have to park with the car in gear until I can sort it
The nearside brake works ok but when I fitted the pads I saw that the piston was pitted
Does anyone have a spare set of brake calipers handy?
