I am wondering what sort of price I should be paying for a cam belt / cam belt kit for my 1990 1.6 BX meteor (hope that is enough info) ?
Just the bits, not the fitting - I need to price the job up as I reckon it's a must do this year for me.
KP
Price of a cam belt / cam belt kit ?
soxer123
1990 BX Meteor 55k
Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read - Groucho Marx
tom
- Citroen Sorceror
Oh god, are Gates still in business? They were sh!te...
Er, a cambelt should set you back around £10 plus the Vodka And Tonic.
A tensioner is about £25 +VAT.
Or at leat they were last time I got some from GSF.
Part numbers N13117 (belt) 113 tooth
N13166 (tensioner)
Chris G
N13166 (tensioner)
Chris G
- Our Trim Guru
There were tensioner kits (presumably to include tensioner & pulley) available from GS & F when I last looked, which seemed to undercut the price of the individual items. Check out the contents/availability of such a kit before buying if going for the whole cambelt & tensioner refit.
However, I'd strongly recommend doing cambelt only if it's your first, enlist the help of someone who has done one if that's the case, and shy clear of tensioners unless there are tensioner problems to be resolved on an urgent basis - in which case experienced advice/help is a must as the consequences of getting this less then 100% right can be unpleasant, expensive and immobilising...
At least a petrol cambelt should be more straightforward than a diesel one on grounds of space, unless it's a 16v.
classic2cv
- x 117
GSF still list the tensioner kit : 'N13085 CAM BELT TENS SET' at 36.50GBP.
This is a stunning price, nearly half that of the individual parts.
I think I will get one for my upcoming engine change.
Never used a QH cambelt so couldn't say really. But if QH belts are as crap as QH clutches then, er, hhmm.classic2cv wrote: i've just got a Quinton Hazell timing belt for my TZD, are they ok?
I've always used Dayco belts, they are as good as it gets, and not expensive!
