DUFF ABS
tim leech
DUFF ABS
Mine doesnt work although I have replaced the non ABS driveshaft with a correct one (thanks Ian), the ABS light went out once for about 2 seconds a while ago but stays on continuously. Is there a easy way to find out whats up, I imagne its a sensor? Is there a way you can clean these sensors?
Stewart (oily!)
Stewart (oily!)
On mine I found 3 defective sensors - and both back ones had failed as a result of the outer cover becoming porous and allowing the screening to corrode. The trick is to find the defective sensor first - by metering at the plug - then cut the cable at a convenient place, meter the sensor side - and if it still doesn't conduct - cut it back a bit further - until it does work. Do the same the other way then strip the wire back and solder in a length of flexible co-ax cable (not like TV aerial cable which has a solid centre conductor)
You need to insulate carefully, both the centre conductor and then pay careful attention to waterproofing the outer.
tim leech
Get a agarge to check them if it's beyond your skills tim, seems pointless spending money on sensors you may not need.
Ok, it's most likely a sensor gone done, but it could be the relay, oh, and not forgetting the pesky little diode in the wiring loom. Shouldn't take a compentant garage long to locate the course of the trouble which has got to be cheaper than buying 4 sensors and hoping for the best??
tim leech
