Alan S
Let the games begin.
AlanS
Picked up the front mudguard today to replace the well mangled one but on a closer look, it appears that besides the front guard, I'm going to have to give the roof of the wagon a coat as well. Being an Estate, it has a roof rack which appears to have screws to remove the main side pieces but does anyone know what holds the rubber strips that run along the top of the turret? Double sided tape perchance? if so, what chance do I have of firstly removing it and secondly get them sitting flat and straight. Also the antenna; do I have to remove the hood lining to get it out?
Alan S
Alan S
M
Re: Let the games begin.
Cant comment on the roof bars - but with regards the aerial - if there is no handy light assembly in the passenger compartment underneath (and I thought there was on BX's), if its like the Xantia, then yes its hood lining out to undo the little 10mm nut holding the whole caboodle on.AlanS wrote:Picked up the front mudguard today to replace the well mangled one but on a closer look, it appears that besides the front guard, I'm going to have to give the roof of the wagon a coat as well. Being an Estate, it has a roof rack which appears to have screws to remove the main side pieces but does anyone know what holds the rubber strips that run along the top of the turret? Double sided tape perchance? if so, what chance do I have of firstly removing it and secondly get them sitting flat and straight. Also the antenna; do I have to remove the hood lining to get it out?![]()
Alan S
AlanS
