sun roof deflector
charlie
sun roof deflector
Post by charlie »
is there suppose to be a flexible rubber seal on a deflector or is the seal a black rigid plastic??
am looking at one now and it looks to me as the seal has hardened over time..
ta
charlie
yes.....
the colour is....
guiness white..........
Our Trim Guru
x 13
Post by DLM »
Hi Charlie. I had one of these seals which I never fitted, but I seem to remember that the seal was rubber..
charlie
Post by charlie »
hi dave,
it would make more sense, a rubber seal :idea:
its the first time i've seen one up close and the rubber has hardened so much its turned brittle and i guess the whole deflector is now useless :roll:
charlie
yes.....
the colour is....
Brian King
BX 4x4 Owner. Brave.
sun roof deflector
Post by Brian King »
I've got a blue tinted sunroof deflector and would prefer a grey one. Swop or buy.
Brian King
Edit by Jon, phone number removed, please send private message to Brian instead, thanks
stuart_hedges
Post by stuart_hedges »
Just a hint - I don't recommend posting your real name next to your home phone number on the internets!
The guys on the board are trustworthy but don't forget this can be read by *anyone.*
Welcome, by the way :) I see you joined in September but I don't think we've "spoken" before...
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
Charlie,
Somewhere, I have a contact who can supply the rubber seal and I think the clips too...although I made mine up so I can make some for you too.
There is an alternative to the black rubber seal and that is some 6mm tubing with a slit down its length. I've done on my TD and although I'll eventually but the proper one, it's only a couple of quid and does the job ok... :wink:
Brian King
SUN ROOF DEFLECTOR
Thanks Stuart. In keeping with everybody else, here are the BXs I've got:
BX GTi 4x4 1990
BX GTi 16v 1989/90
BX 17 TZD 1991
All in reasonable condition, except for scrappy foglights, and the 4x4 hot/cold heater control is jammed and the sunroof solenoid doesn't work.
Plus a 1984 GS Special break (estate). Not in the best of health.
Oscar
Post by Oscar »
@ Brian - welcome to the forum. I really would go back and edit your message to remove your phone number. Just click the "edit" button in the top left hand corner of the message.
@ Bandit - how did you make your clips? What are the dimensions? I have the deflector, seal, bolts nuts and lack the clips. I'd be really grateful for a pointer.
Oscar
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
I'm about to swap them over onto the 16V (if she passes the MOT this week!!) I have made them out of 1mm galvanised plate (not as nice looking as proper black clips but they do the job) I'd make you a set ...but... it depends on how deep the deflector is where it bolts on. Am a bit busy till next week but I'll sort something out..
