Just need someone to confirm I'm not mental really....
As you may or may not know, Saxos have an electric power steering pump, rather than a belt driven unit. These are prone to failure; right about now, basically.
Now its my g/f's car, and due to her being a poor student she's gone and bought a second hand unit from a scrappy. I fitted it today and it worked initially, but then failed to work the second time I started the car. It did make one odd noise prior to working too, and now theres nothing, just like the original pump. I've checked the plug on the loom and there is a healthy 14.4v going to the pump, but no reaction from the pump.
The connector itself is in A1 condition.
Both pumps are duff, right?
Non BX query
- x 94
Non BX query
Mr B
- Northern Moderator
I've heard the ignition switch can give problems on the Saxo by failing and cutting out the P/S pump. Worth a look?
Just found this on another site.......
"No need to change the switch.There is a wiring modification to the wiring at the ignition switch :there should be 3 two pin plugs brown, grey & black coming off the switch, un-plug brown connector leave the side that goes into the switch untouched, then the 2 wires on the other side going into the harness should be joined together (preferably soldered) to make a loop in the wiring. Do NOT join the part that goes into the switch. Hey presto P.A.S.,heater blowers working again.you'll probably find the heated rear window was not working either."
1991 Landrover Discovery
1995 VW Golf SE
1995 VW Golf SE
- x 94
RichardW
The brushes gum up in the motors causing intermittent operation. You need to strip the motor down and clean out / free off the brushes - it should work OK then - you will probably find the original will respond to this as well. My colleague managed it with the pump still joined to the hose unions on the car, as he couldn't free them. Worth a punt as a new pump is > £200!!
I NEED a BX TD.
- x 94
RichardW
Def a Saxo pump - it was a couple of years ago though. I'm sure I found a post on the Saxo list on Yahoo about doing it - but didn't turn it up on a short search just now. I don't think it looks like you should be able to get it apart, but ISTR it's just a case of bending the tabs back so that you can prise the end cover off, and then take it from there - just like a starter motor really. You may well find it will respond to a sharp tap from a hammer handle to get it going temporarily.
I NEED a BX TD.
