Leaking water pipe
Barnsley BXer
Leaking water pipe
Advice needed please.As above,I've got a leaking water pipe.It's the braided one that appears to come from the back of the head(you can see it if you look between the water pump pulleys).It then goes across the back of the engine and couples up to some more pipes on the driver's side.Is this a dealer part?Is it available from GSF and the like?What do I need to remove to get to it,other than the obvious intercooler?Any advice gratefully received
1990 GTI 4x4
1992 TZD
1992 TZD
Mr B
- Northern Moderator
And be VERY careful removing the pipes from the matrix, the plastic pipes get brittle and break very easily.
If your strapped for cash Dean, and identify with pipe it is, I can send you a second hand (but leak free) pipe gratis..
Barnsley BXer
Thanks for the replys lads.It's the one that Jon mentioned first(the easiest.Suppose every cloud has a silver lining
)Thanks for the offer of the pipe Doc,but I'll get a new one.Knowing my luck,the unleakiest of pipes will start pissing water out the week after I have fitted it
1990 GTI 4x4
1992 TZD
1992 TZD
Barnsley BXer
Barnsley BXer
