Alloy wheel bolts question...
PiLsY.
Post by PiLsY. »
Does anyone know the size of bolt I need to fit xsara exclusive alloys to the front and 406 alloys to the rear? Its just the actual shaft length I need. Went to halfrauds and they tried to sell me the steel wheel bolts (25mm) as alloys and told me I wasn't able to refund if they weren't right as they were special order - bugger that! I'm guessing they're either 32mm or 35mm, but I'm not risking a wheel falling off to I thought I'd better check :D.
Failing that if anyone has 16 bolts they want rid of then let me know, cash/tokens/favours as applicable...
Cheers,
Matt.
