[/img]
We had one guy on the previous forum who was from NZ who was determined to do it and managed to get some kind of portable hydraulic press on the job (Port-a-power?) and after heating it, did eventually get it out and pressed it back on, but if it's so tight a fit (is this what they call a shrink or a press fit?) that heat and hydraulics are still battling to remove it, I could imagine you could stand a real good chance of having the lot wandering up and down the rack on a hot day given the right set of circumstances. From memory, the guy who did it we haven't heard from since, so that might say it all!Mr B wrote:We gave up trying to remove that bit over at Jon's earlier this year, Tom tried heroically with much frowning and teeth grinding to shift the bugger. After a fewwe came to the conclusion it was easier to swap the rack for another unit
Strangely enough, the rubber ones seem to outlast them; I can't speak for over your way, but here the plastic seems to go just like a piece of semi hard plastic left in the sun and it looks like a heap of plastic washers floating up an down the shaft in no time. The plastic also seems to tend to scuff and wear holes through it.Mr B wrote:Could be the reason why they are built with a type of plastic boot not rubber, so they last longer. The one on Jon's was in a poor state due to the possibility the battery may have leaked on it.
