Hi all
Just thought i'd let u know that my meteor passed her mot. Interestingly the noise that i get when i put her into reverse is actualy the starter motor catching sooooooo i have now found that if i put the key in the ignition i can start the car by putting her into reverse!!! anyone know ought about this?
BX 1.9 quirky talents
Numptychucker
go further on veg oil
Is it manual or auto?
Sounds like something is shorting in the reversing light circuit - most likely in the common parts shared with the starter circuit - so the common looms would be my first suspect.
I'd start by having a really good look around for physical damage - then I'd remove the connection to the reversing light switch and re-wire that either to the rear cluster or (neater) to a point where the loom wasn't shared with the starter circuit - making sure I disconnected (and carefully insulated) the now redundant newly by passed wire.
