Is it the driveshafts?
Oscar
Post by Oscar »
Hi
I have a developing vibration through the steering wheel. It used to be most evident at 90mph, so not a problem. Then it became evident at 80, and now it's apparent at 70-75mph.
Is this driveshaft wear developing? If not, what else might it be? And what would I need to repair and renovate things? Are new driveshafts available?
Oscar
m_2975
My Cars: 1989 BX 19TRI Estate
1993 BX GTI
1997 Xantia CT Turbo
Post by m_2975 »
Oscar,
I'd tend to think a wheel balance is in order for the front wheels.
Give that a go.
Normally the gearstick shakes with a damaged driveshaft.
My Cars:
'93 BX 19GTi Sedan 5M
'89 BX 19TRI Estate 5M
'89 AX GT(With EFI) 2door 5M
In the Family:
'74 SM IE (Fully Restored) 5M
'90 BX 19TRI122 Sedan 4A
'06 C5 2.2HDi Estate 6A
mnde
Meteor Man
Post by mnde »
Also I'd have the tyres checked for delamination at the same time. My old Meteor was diagnosed with this - with the car on ramps, my mechanic spun the o/s rear wheel to show me how the tread rings tracked from side to side, when they should be perfectly true.
Mark.
tom
Citroen Sorceror
x 38
Post by tom »
Stuck the back tyres on the front. Stick the front ones on the back. Test drive. Same symptoms? Driveshafts. It gets worse fairly suddenly and then the gearstick shakes like hell and the car scrabbles for grip pulling away. If your car is non-ABS, DLM is currently plundering a Tizzydee so I'll PM you his number
Oscar
Post by Oscar »
The tyres are new, so won't be delaminating yet. The tracking needs to be done.
I swapped front and back tyres a while ago, but the handling was awful - pulling to left and really rough - left to itself the car would have driven in a figure-of-eight!
The gearstick IS wobbling slightly, and there have been one or two scrabbles of late - but that may be my driving style.
So it looks like the jobs are: replacing the octopus, the bottom engine mount and the driveshafts. Lena WILL be pleased...
