big wheels
classic2cv
big wheels
Post by classic2cv »
what are the biggest wheels that i can fit to my TZD estate without modding my rear aches ? (much) :wink:
Citroen BX
Origami in plastic and steel
^^ ^^^^bx>
Ian_Fearn
Post by Ian_Fearn »
I think part of it depends how good your rear arm bearings are! :wink:
Pretty sure Billy put some 15's on his estate.
Wonder what a BX would look like on a set of 20 inch chrome spinners....
Mr Chidlow, can you do me a photoshop? :?: :idea:
Over and out from me
tim leech
Post by tim leech »
You can fit 17" wheels as long as the arm bearing are good, but you cant do more than a 205 tyre? But it will ride like the spheres have gone!
Give me a while. I am Photoshopping like mad at the moment - it's what I do... but for Gawd's sake I need a break :lol:
classic2cv
i might have the option of 15's on my estate. (195 tyres) :D
Citroen BX
^^ ^^^^bx>
BX 16v alloys go on, but its a very tight squeeze. The fill the rear arches out to say the least!
I imagine 15's would go with a 195/50 setup though, as the overall RR isn't much different to the 16v alloys due to the huge boyancy aid tyres they come with!
Our Trim Guru
x 13
Post by DLM »
My personal view, whether relevant or not: there's a world of difference between what are the biggest that can be persuaded to fit and what will make a sensible choice for the car.
Also factoring in the effects of the non-design-spec wheels is at best an inexact science. I work from first principles and if adding in something that will cause larger moments (and more potential for mechanical wear and tear) I'd consider it very carefully. First-principle Physics can tell you quite a lot.
You might find yourself changing rear arms more often , and with more difficulty (as if anyone needed that), though you'll get the warniong signs much sooner. I've also seen recently what can happen when standard-fit 185 alloys are fitted but care is neglected when tightening the lengthier wheelbolts & a hub thread gets stripped as a consequence. There's greater scope for that sort of thing the more non-standard you get...
classic2cv
Yes I can agree with you totally
I only asked to find out if I could fit a set of 15” alloy wheels to my TZD estate
But I noticed that the gap between the rear wheel arch and tyre is quite close as standard and I didn’t want to modify the body visibly
And as you say more grip means more wear and tear on the running gear 8)
Citroen BX
^^ ^^^^bx>
Post by kiwi »
I had a set of 15 inch tyres I was going to fir to the Rear of My BX and the overwhelming advice from two Tyre fitters was DO NOT!
Sensible advice I guess.
Mike P
Post by Mike P »
I ran a Bx16v with 17" x 7" wheels on it, with 205/40/17 tyres in it. Offset was 15mm.
Front strut clearance was fine, just had to cable tie the handbrake cable to stop it rubbing. Rear inner arches were trimmed by 5mm to
flush them with the arch extensions on the 16v.
Looked something like this :D :
Mike P.
Cornishbx16v
Post by Cornishbx16v »
i also ran 17's on my 16v, same offset as mikes! (et15) and has only to file some of the fibreglass on the rear of the side skrt to get them to fit without rubbing (only when in low)
Timmo.
After all I AM CORNISH!!!!
www.bx16v.com
www.bx16v.co.uk/forum
www.bx16valve.co.uk
Post by kiwi »
Dont forget the speedo error your going to create as you pass one of the many fixed camera sites in the uk :lol:
Well, kinda, as long as the rolling circumference of the tyre is the same the speedo wont be affected.
Mike P
Post by Mike P »
Using tyresave.co.uk tyre size calculator, the difference between a 195/60/14 tyre on a 16v to a 205/40/17 is + 1.02% on the diameter.
If I can do my maths right, that equates to a +0.817% increase on the circumference, so if I was doing 100mph on the speedo I would actually be doing still less than 101mph, more to worry about at that speed than percentages :lol:
Mike P.
Isn't it a bit over 3%?
The circumference if the wheel is its diameter x pi - and pi approximates to 22/7 (or in rough terms a bit over 3) - so if the diameter is 1.02% greater - the circumference will be 1.02 x pi (or a bit over 3) = 3+%
