To cut a long story short, my BX16 conked out on the way back from Brighton yesterday, where I'd been visiting with the good Mr Stuart Hedges of this forum. I had to be trailered back to Guildford from Pease Pottage services on the A23
What happened was I pulled into the services for a quick loo break, then as I was driving slowly towards the carpark exit, the engine cut out - and I couldn't restart it. I pushed it into a space out of the way, then tried again.
I should note at this point I've never had any trouble with hot starting before.
With my foot flat to the floor, the engine fired... but then quickly died again. Then a couple of times I was able to start normally, but each time it would run normally for c. 10 seconds and then cut out. Even if I maintained 2000 revs, the rev counter would suddenly plummet to zero and the engine died *instantly*. Honestly, I've never seen the rev-counter drop so fast.
After that, I couldn't get it to fire again. The AA man came, and declared that there was no spark from the coil. The engine was just turning and turning, no hint of coming to life. He checked the coil connections... but couldn't see where the wires disappear to (some flywheel sensor??) to verify the connection down in "the innards".
The car was perfectly fine when I set off from Brighton!
The HT leads are new, sparkplugs and dizzycap/arm date from late last year. The only thing I've adjusted recently was the timing: I retarded it slightly last week to eliminate pinking - then realised I'd adjusted it a bit too far because I had trouble with cold starts (revs too low), and nipped it back a tad on Saturday morning, which cured that problem. Oh and I need to repair the carb hot air tube - two halfords hot air tubes duck taped together - because the duck tape join failed when I moved it out the way to adjust the dizzy the first time.
Any clues as to what's happened because I'm flummoxed here!!
Cheers,
Mark.
