Urgently needed, Bonnet catch!
ed4ferrets
Jon, when I locate the elusive reclusive (hopefully tomorrow) I will try to acquire the catch from his knackered TZD... will let you know mate>
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
- x 94
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
- BX Digit man!
- BX Digit man!
It wasn't all bad mate, the car was a scrapper anyway! By the time I'd destroyed the windshield, I'd already gas-axed the front off!!DavidRutherford wrote:
You complete plank!![]()
Although, yeah, I hadn't actually intended to put the engine through the glass, it just kinda, well, happened, too many
- BX Digit man!
Ah! slight difference then! I thought you meant you'd put it through the windscreen of a decent car.docchevron1472 wrote: the car was a scrapper anyway! By the time I'd destroyed the windshield, I'd already gas-axed the front off!!
When it's a scrapper anyway you do tend to do things differently don't you. I wanted to keep the engine and front suspension of a BX... so just cut it off at the bottom of the A-pillars, and across the floor just in front of the gearstick...
- Our Trim Guru
