Help!! big leak
classic2cv
Help!! big leak
Post by classic2cv »
I’ve got a bit of a leak
but I’m having a bit a problem tracking t down
After sorting out the regulator (just a case of tightening a loose junction )
I now have another to sort out
I thought that it might be the octopus but that seems ok and the height corrector looks ok too
maybe I have a cracked pipe somewhere as It seems to be coming out under pressure
Any ideas :roll: ?
Citroen BX
Origami in plastic and steel
^^ ^^^^bx>
Stewart (oily!)
Post by Stewart (oily!) »
Steering is in that area too, can you run it whilst you are under there looking?
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Post by kiwi »
Little observation in the picture there is a threaded union fitting that is not connected to anything in the top left hand corner.
Just a hunch but does something with a thread on th end of a pipe have to go somewhere?
Post by ken newbold »
Octopus!
It'll be the leak-off pipe from the height corrector. Only leaks when engine is running?
The other possibility is the power steering return, easy fix. But when this goes you usually run out of fluid very quick.
I'm sticking with Octopus. Can be a temp fix without having to fit a new one.
Post by kiwi »
Wife just told me I need glasses :lol: optical illusion ignore what I said and I go with Kens Octopi theory.
prm
LHM Leaks
Post by prm »
I’ll go with Ken –
But leaks around the octopus area can be a right s-d to track down sometimes.
Have a look at the front height corrector if the octopus is ok. You need to remove the front wheel. Viewed above the drive shaft, through the opening, there’s a small 8-10cm, piece of rubber hose that pushes onto a spigot on the height corrector and then bends upwards to connect vertically to a steel or plastic return tube. These small sections start to leak around 100-140K.
Aerosol degreaser works fine in clearing surplus oil, then wrap small pieces of white loo roll round each pipe , secured with cloths pegs (sounds all a bit domestic!!!),.gives a good direction where the leak is coming from
classic2cv
i've had the wheel off and i'm still not able to see where the lhm is leaking from
does anyong have any photos of the area around the height corrector ?
Citroen BX
^^ ^^^^bx>
are you joking :lol: you'd need one of those medical camera things to get in there
classic2cv
i'll have another look in the morning
i can get close to source of the leak but just can't see where it's coming from :evil:
can it be takled from the top?
Citroen BX
^^ ^^^^bx>
From under the wheel arch I'm affraid.
You need a very good light. some clean tissue. Lots of.
If you have big hands it will be difficult. I usually manage without taking the driveshaft out.
Look for the height corrector, then find the return pipe, it will be facing you but concealed. Clean the rubber return pipe and you'll probably find a split in it.
If you have a piece of metal brake pipe to hand, it is possible to make a repair by bending a metal pipe to shape and then inserting it into the octopus and then a new bit of rubber pipe to connect to the HC.
I have a spare octopus here if you require it. That should keep you busy this bank holiday.
classic2cv
Thanks ken :D
i'll have another try in the morning
and it might be taking you on that spare octopus
should i be brave enough to try and fix it 8)
Citroen BX
^^ ^^^^bx>
If you clean, and I mean clean, the front area of the subframe. Then run the engine for a while, you may well see a trickle of LHM running down the area I've marked.
If this is the case, I can almost gaurantee it's the HC return pipe split.
classic2cv
yes that’s exactly where the lhm runs when I wipe the sub frame clean
It takes about 15 seconds to start running off the sub frame again
Citroen BX
^^ ^^^^bx>
So now you know what you're looking for.
classic2cv
i've found it
i'll have to grope around by hand (if i can get my big hams in there) and do it by feel
a couple of clips a bit of break pipping and i that were all sorted :D
i'll bid you good night and I’ll let you know the results later
Citroen BX
^^ ^^^^bx>
