Radiator grill
Radiator grill
that plastic thing that goes in front of the fan(s) - there's one up for grabs on ebay here, seller can't specify model. I need one for the TRD so I took the one off the RD to see if it fits. Problem is former is long nose latter is short. Lowered the bonnet slowly to see if it will fit - has extra grill pieces to fill the larger gap on the short nose - then the blasted thing shut! No way to get access to the bonnet release. Managed to slightly lift the bonnet at the corner and get a broom in there ( not citroen tooling) and release it..
Think the short nose grill can be modified to fit. Leads to question - how many types of grill are there - could I buy one that is completely wrong? Cheers!
Ok, it's too early on a Saturday morning to be discussing grills. Thought it wasn't technical enough for the technical section.. bought it anyway for a whopping €3 will make it fit if it's the last thing I do :)
