Bits Wanted for 16TGS
tim leech
Post by tim leech »
Right where do I start,
Inisde: In grey please,
1. dash clock tray (with digi clock/cut out please)
2. Pair of door speakers (standard are fine)
3. Pair of door speaker Grilles
4. Rear parcel shelf (no holes please!)
5. Passeneger side rear C post panel (inside)
6. Sunroof Motor and Switch.
7. Switch blank for centre console
Outside,
1. Passenger Front Wing (must be in white)
2. Sunroof deflector seal (yes I know ha ha)
3. Petrol cap filler metal seal (the part that the cap rubber seal itself locks into thats held in by 3 screws onto the body)
Please let me know what you have thanks! Cash waiting!
tim leech
Post by tim leech »
Cavmad did u have a wing from the TZD?
Stewart (oily!)
Post by Stewart (oily!) »
I have a slightly scruffy white wing, just needs a little paint, I can bring it to the national if needed.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
tim leech
Post by tim leech »
Thanks Stuart the one on the TGS is also damaged so was trying to get one that I can just bolt straight on instead of painting etc.
tim leech
Post by tim leech »
Have managed to locate all the bits I need now guys thanks.
Wow, that was quick, look forward to seeing some pics....
tim leech
Post by tim leech »
Fortunatly someones breaking a identical car (even same colour) so thats been a god send.
I do still need the sunroof seal deflector seal though
How about cutting up a bicycle inner tube?
tim leech
Post by tim leech »
Thats a thought mate, thanks.
Incase u couldnt get a proper seal, it should work ok????
