TAILGATE
larry
TAILGATE
Post by larry »
Wanted BX tailgate hinge pins if anybody is breaking a bx....Larry :) ps 1993 tzd..hatch. it has a lot of play moves side to side, and rubbing on the roof...Larry :)
mountainmanUK
Post by mountainmanUK »
Try taking one down to your local Nut & Bolt / Engineering Supplies place!
If they havn't got an exact match, they WILL have something that will fit!
P.S. Still too loud, matey! :wink:
Fix:
Locate "Caps Lock" key (at left-hand side of keyboard), press aforementioned key to release "Caps Lock" (The "Caps Lock" warning light will go out!), continue to type in a nicer, quieter, more friendly manner! :wink: Typing in CAPITAL letters is considered to be "shouting" on Forums etc.!!!
Good Luck with the Hinge-pins!
Post by ken newbold »
Have you checked the spring clips that hold the pin in place?
I cannot see the pins being at fault. They should have a square section on one end and are held in place by a metal clip. :?
larry
Post by larry »
Thanks Ken i will check in the morning :)
K REG CITREON BX TZD
