electrical earth fault???
charlie
Post by charlie »
have got what i think is an earth fault
most obvious to see when the rear lights are on and they fade/blink when the hazards go on and off...
am not that clever on electrics so would appricate if anyone can point me in the right direction, places to check,
ta
charlie
yes.....
the colour is....
guiness white..........
The rear lights earth through bolts attached to the body inside the light units. You will see a bolt with a number of loop terminals under it - that's the one.
The other likely problem is the plug onto the light unit - remove the unit, take the plug off and put it on again a few times. Some switch cleaner can be used and may help. Some people use WD40 but its an electrical insulator but this characteristic doesn't seem to cause problems. A good clean and scrape and re-tension of the terminals works wonders.
Keeper of the site Goat
Post by cavmad »
As Jeremy says I have found removing the bolt(s) which hold the earth wires in and cleaning up the bodywork with emery paper before refitting can do a really good job.
Vauxhall apologist.
AlanS
Post by AlanS »
When I had the mechanicals out of the TZi, I thought it was a good time to do a bit of general tidying up, so I pulled every plug I could lay my hands on apart, washed it out with degreaser, rubbed it over as far internally as I could reach with a brass bristled brush about the same size and shape as a toothbrush, washed out with WD40 and then sprayed with contact cleaner.
Reconnected, ran a piece of insulation tape aound the outside at the point where the two sides meet and then held the plug together firmly by running a zip tie over both endsI found when pulled apart, most terminals either had corrosion or greasey oily scum over them and I cleaned until this was all gone.
Result has been the best lights I've ever seen on a BX and a starter that spins so fast it almost throws the engine out of the car.
Takes a while to do, but worth the effort IMO.
Alan S
Post by cavmad »
In the absence of de-greaser I have found choke and carb cleaner does an excellent job of removing grease and slime etc. It should flash off too and leave a nice clean surface to apply grease or insulation tape to.
Vauxhall apologist.
charlie
Post by charlie »
thanks everyone problem now sorted
did as you suggested and cleaned the contacts,
lights all became brighter but still fading. Then saw front left indicator was not as bright as the others so played/cleaned with this then and hey presto everything ok :D
although now have another question for you lot. what do i put on electrical contacts to keep the water/damp out. i see the battery itself has some sort of gunk on it. cavmad mentioned some grease, what exactly is this stuff
ta
charlie
yes.....
the colour is....
I use vaseline.... and for the car...BOOM BOOM. :roll:
docchevron1472 wrote:I use vaseline.... and for the car...BOOM BOOM. :roll:
Given up on the KY Jelly then Doc? :wink: :lol:
Yeah mate, it's less embarrasing asking for vaseline! :wink:
Yeah but, they tell me vaseline causes rubber failure. :? :wink:
charlie
Post by charlie »
ahhhh
the wonderful world of petroleum jelly
but i wont be able to buy some now without blushing :oops:
charlie
yes.....
the colour is....
Way2go wrote:Yeah but, they tell me vaseline causes rubber failure. :? :wink:
Not a problem for me, I use Michelin bus tyres! :wink: :lol: :lol:
mike st gilles
Post by mike st gilles »
Fnaar, Fnaar ooher missus! :lol: :lol:
Mike
charlie
Post by charlie »
i know ive not been on these boards for a while but really gentlemen, one must not fall victim to crude, base and cheap innuendos
we bus drivers, doc, are better then this
but, if you give us your mobile number and ill send you something really, really bad
and its made out of rubber too
charlie :wink:
yes.....
the colour is....
PM sent my good man!
