External window seals
CitroenCrazy
I didn't notice until I bought my first BX a few weeks ago, but it looks as if the external window seals seem to shrink.
Mine looks like the others I've seen recently, in that there's almost a 1cm gap at both ends.
Has anyone identified a donor vehicle that has slightly longer ones that (a) fit and (b) look right ?
I haven't been outside to measure them (if the rain ever stops....), but I guess fronts could be cut down to fit rear doors, but what about new / better fronts ?
TIA Andrew
1989 BX DTR Turbo, only 44,000 miles
GSA x 3, GS x 2, DS x 2, XM, HY
TIA Andrew
tim leech
simonbx17
me too
mine's the same too. this is my second bx with this problem on the passenger sidein the top corner of the window, would be interesting to hear anyones solution to this.
what the misse does for the journey is put tissue in the gap and that seems to dampen the extra wind noise that you get!!
Current.
prm
It could be due to the channel seal moving down the door recess grove.
If you lower the window, prise out the seal and pull upwards to gain the extra distance required. Some are quite stubborn to move, try raising the window at the same time. Usually you end up with a bulge at the top and the window fails to close fully. If you raise and then lower the window, forcing down the seal with the window moving to obtain the correct, noise free!! fitting.
May require several attempts.
Are we talking about the seal which runs all the way round the window or the rubber bit along the bottom of the window?
Yes the window seal does pull down with opening movement of the window and is easy enough to get back up. A spot of adhesive will cure this.
If it's the rubber bit along the bottom of the window, yes they do seem to shrink
simonbx17
cheers m8, but mine has abit missing at the top like it's been cut does any ideas where to get a replacement?
thanks
sorry citroencrazy for hijacking your post. it's a now you come to mention
it type of thing.
thanks
it type of thing.
Current.
simonbx17
yes..........i think theres been crossed wires here
cheers ken
cheers ken
Current.
simonbx17
thanks guys for your info, unfortunately i won't be able to make the national as short of cash trying to get my bx road worthy and maybe
taking on rents st tropez..
Current.
sausage
Are these boom seals still available from Citroen? Mine have all gone hard and don't seal too well. Was hoping to find new as I can't imagine ones from scrap yard being in any better condition.ken newbold wrote: If it's the rubber bit along the bottom of the window, yes they do seem to shrink
Sorry for the thread hijack over
There are independent rubber suppliers who hold stock of all sorts of wonderful profiles. It may be that the window bottom seal (or others for that matter) are similar to a standard profile and you can buy new.
You may find someone publishing profiles on the net. You will find local distributors in yellow pages.
