But here are a few questions :
1. What is the CORRECT setup for the injector pipes, i got it set up like this:
but im not 100% its right. A photo would help the best, but a description would do!
2. What the hell is this????
its on the side of the radiator, connected to some wiring.
3. I lost a radiator plug, is there a way to botch one, I found a well fitting cork, will it take 1bar of pressure? (ill go to the scrappie later).
4. Anyone know a sure way to tell a UK left dipped headlight from a EU right dipped one (i mixed them up, and now im guessing by manufacture date).
5. I still got a slight leak of the green (LHM) under the drivers side underside, theres a copper pipe and a transparet one, further up there are hard metal pipes, any ideas? What usually goes wrong on the hydrulic lines? can it be patched up?
6. One more thing, how is the Oil filler fitted to the engine bloc? Is it pushed inside or resting on the outside?
thanks!
J
