The Meteor is still out there
classic2cv
Post by classic2cv »
yes folks
the Meteor is still out there
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... &rd=1&rd=1
and getting a bit cheaper
all the bits seem to be there, it does need the sunroof insert to be replaced (all the bits needed will be supplied)
it's only has 77k on the clock
with a good clean up it could make someone a nice little car just in time for the CCC bash next month
if it needs to be moved a small distance i may be able to tow it with an A frame
somebody save it :)
Citroen BX
Origami in plastic and steel
^^ ^^^^bx>
tim leech
Post by tim leech »
Is the sunroof/headliing still there ? What was the estate car like, did you end up with it.
classic2cv
tim leech wrote:Is the sunroof/headliing still there ?
yes i think that all the bits are there
he has lots of spares so it should be a problem getting the sunroof sorted
i think that the rest of the mechanicals are also in good nick and the body is ok too
it just needs a little TLC to get it back on the road again
we collected the estate yesterday, towed it home with an A frame
It runs ok has good suspension and hydraulics it even has prefect working ABS
but the body is a bit past it will make a good source of spares
Citroen BX
^^ ^^^^bx>
tim leech
Post by tim leech »
Oh well better that than being squashed!
