Front wiper motor
Front wiper motor
Does anyone have either a new one for sensible money??? or a 2nd hand one that doesnt have any slack in the spindle area??? I think that there are 2 different varieties, anyway of knowing which one i have in the Gti? or can either be fitted?
Post by ken newbold »
I wasn't aware of the difference, unless the plugs are different?
I have one but it's needed for the TZD sorry.
Just found the reply i received from a chap selling one on ebay:
There are 2 makes of wiper motor that fit all Bxs. This one is a SEV Marchall, the other being a Bosch. If your is a SEV Marchall, fine. If it is a Bosch you will need a different wiper drive (the part that the motor bolts on to) good luck Peter.
Blimey, something techie that i know about :D
Mind you, not sure how to get at the motor to check which one it is....
Stewart (oily!)
Post by Stewart (oily!) »
Probably worth making a bush for the floppy wiper problem, a little oil in there seems to last years.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
Er, was that an offer Stewart??? :D
Cheers for that, beyond my skills i'm afraid :(
classic2cv
Post by classic2cv »
Hi Mulley
i might have a wiper motor , i'm just checking it
drop me a line if your still after one
Citroen BX
Origami in plastic and steel
^^ ^^^^bx>
Bit short of funds at the mo, so will have to delay in getting that, unless someone has an uber cheapo one thats in good nick???
