wanted please wheel trims
Mallion
Hi all,has anyone a set of trims for my Gti please,1993,14inch??good condition would be preferred.!!i am in suffolk,so no doubt pandp applies. cheers Barry Mallion
- x 27
Hi I've got a set from a '92 GTi (That's 93 model year I think) that were painted a dark graphite metallic when I got them but if you're handy with silver spray paint they'd come up OK.
You can have them for nowt.
I could bring them to the National or if you're down this way, you can collect from Chelmsford. I've also got a VGC Continental tyre (185/60/14) on a GTi steel rim if you want that too... (good as a decent spare if nothing else)
Mallion
wheel trims
Hi Phil ,thanks for reply ,does the graphite look ok or is a respray needed??not much good at d i y !! shall be at the national but only on sunday. cheers Barry M.
- x 27
I'd say respray needed. Why not wait until the National? Simonbx17 has first dibs on them, but he said to mention them to you too in case he doesn't come. Now he is, I guess I should give him first refusal... We can sort it out then, yes?
simonbx17
pm sent.....mallion these are rare wheel trims and are correct for you gti so if you still want them, it's up to i won't mind if you want them......
i would scotch pad them to clean and key them and then spray either plastic primer or just spray them in a decent silver not wheel spray paint silver or they will look to bright and plenty of laquar to seal them.
Current.
- x 27
Mallion
wheel trims
Hi Simon,i think it only fair as you were 1st to let you have them,i am sure you will make a better job than me !!! i hope to be at the rally on sunday so may be able to get a set there. thanks for all the advice.cheers Barry Mallion
simonbx17
hi mallion, no probs only glad to help and thank you.
see you there.
see you there.
Current.
