If anyones got one kicking around, I need the black square(ish) vacuum box type thing which goes on the back of the carb. The studs broken off mine on the RS and it's a bit of a bitch to run cold!
If anyones got one kicking around I'd be grateful for it at the national. Cheers!
1.6 Auto choke carb vacuum unit
- x 94
tim leech
Ian_Fearn
mnde
- Meteor Man
You must have a far better memory than I, Tim, because I can't honestly remember bagging this spare carb that you're bringing for me
I already have a spare 16 carb courtesy of Billy, that I've cleaned up and is now awaiting fitting up with a gasket/diaphragm set, when I can afford it.
How much did you want for it? If I decide I don't want it, then Kitch is very welcome to it
Mark.
Mark.
tim leech
- x 94
