Noticed the other day whilst i was under the bonnet, that the pipe from the fuel filter that goes into the pump, that there were air bubbles going through it.
Before anyone asks how i can see throught black pipework, my car is special and has had a clear section added between the black bits of pipe, so i can see the fuel.
The bubbles werent continous, just now & again, but were largish in size.
Is this a precursor to a major problem or doesnt it matter?
Air bubbles in the diesel??
- x 27
Stewart (oily!)
- Keeper of the site Goat
Maintaining a car - of whatever make is always a matter of skill and judgment. You'll always know that some component isn't as good as new but the judgment comes in assessing if its going to be a problem, kill you or damage something else - or if it'll go on for a while longer or even for ever.
You'll know from reading this board that air can get into the system from numerous causes:
Low fuel level
rotten steel pipes from tank to engine
rubber pipe connections to steel pipes.
fuel heater (pre-black filter cars)
priming bulb (both bulb type and filter mounted)
filter housings (both)
more rubber pipe connections
Leakoff pipes (Bosch pump only - they still fail on Roto-Diesel but just smell and dump fuel over the engine and road)
So there's a preliminary check list - and the question you have to ask yourself is 'Are any of these likely to be the cause of the problem - and what am I going to do about it?'
The air itself isn't causing any problems at the moment - but is your car trying to tell you something?
Low fuel level
Yeah, I reckon your car is trying to tell you to abuse it Mulley!!jeremy wrote: but is your car trying to tell you something?
It loves it when your harsh and manly with it!
Well my son, you've made an easy mistake!desperate Xantia owner wrote: Dear Doc, I've been seeing this xantia for weeks now, I've put the finest fuel in her, serviced her regularly, tucked her up at night and never smoked near her.
But despite all this she keeps breaking down on me, refuses to go to the pub on a saturday and she's starting to sag...
What should I do?
Whilst xantia's may seem like sprightley, goes all night, savage vixens, they are in fact all in their late forties, carrying some extra weight, and are mentally unstable..
Dump the confused wench and get yourself a new ho!
