Running on oil
Martyn
Running on oil
I'm a little confused on the subject of using veg oil(used or virgin). I have what apeards to be a rotodiesel pump, can I put veg oil through it? Is there a simple way to turn waste oil into biodiesel? I have read up on the subject but there seems to be many conflicting methods. Martyn
1992 txd
1991 1.7 tzd
1991 1.7 tzd
tim leech
tim leech
- Keeper of the site Goat
It's fine with the right pump. Either strain the used oil and put it in or buy new. Must be pointed out that using new vege oil attracts the same rate of duty as diesel and must be declared and paid for.
It does stink, to high heaven as it goes, but the car will actually run better on it providing you have the right pump. Now you can use it free of charge with the latest govornment initiative.
Vauxhall apologist.
ed4ferrets
- Yahoo Messenger: [email protected]
How does a Lucas pump stand up to it ... anyone?
I've got 80l of uvo ready to be processed to biodiesel ....
'94 XM 2.1TD Break
'63 Renault Caravelle
'94 XM 2.1TD Break
ed4ferrets
Luckily it's not the interior that honks Tim, just the exhaust fumestim leech wrote:I know its saves money but it seems a heck of alot of mess and hassle, as much as I love fish and chips I wouldnt want my car to smell of it
And ditto to your second post
'94 XM 2.1TD Break
'94 XM 2.1TD Break
Ian_Fearn
stuart_hedges
I wouldn't phrase it quite like that... you know all about it when a chippy-fuelled car goes past but it's not an unpleasant smell.cavmad wrote:It does stink, to high heaven as it goes,
It happened to me today - my nostrils flared and I looked around for the chip shop, only to find that my nose was following a fairly new Merc rolling along in slow traffic! A slightly confusing blend of imagery from nose and eyes.
- BX Digit man!
About the only Diesel injection pumps to NOT use their fuel for lubrication are mercedes-benz ones. Bosch pumps also use fuel for lubrication.Ian_Fearn wrote:From what I understand the Rotodiesel pump uses the diesel for lubrication. Thick vegetable oil is too viscous and can damage the head.
The issue with viscosity can be fixed by raising the temperature of the oil to "hot coolant" temperature, but you're then looking at the complexity of the twin-tank system, with heated fuel lines, separate returns, multi-port valves etc.etc.
M
and of course GARDNER commersial diesels, but then the pump weighs nearly as much as a hole BX engine so......DavidRutherford wrote:About the only Diesel injection pumps to NOT use their fuel for lubrication are mercedes-benz ones.
Ian_Fearn
Interesting, but it just goes to show how much conflicting information there is on the net on the subject.DavidRutherford wrote:About the only Diesel injection pumps to NOT use their fuel for lubrication are mercedes-benz ones. Bosch pumps also use fuel for lubrication.Ian_Fearn wrote:From what I understand the Rotodiesel pump uses the diesel for lubrication. Thick vegetable oil is too viscous and can damage the head.
I consider my diesel to be dirt cheap to run anyway.....
Over and out from me
mike st gilles
Both my (Bosch pumped) Cits (Xsara and BX) run on an average mix of 50% sometimes more and sometimes less.........I'm never that anal about whether its time for diesel or Svo....never had a problem and now with the 2500L limit; that should cover all of the mileage even for the 'work' car. But lets face it, 53p a litre.......cheeeeeeeap!
Mike.
Mike.
Mike
