I know it's not a BX but I know that some bits are common, plus a few members do run Xantias...
I am breaking a 1995 1.9TD; however the engine is spoken for already! Everything else is available but the gearbox does whine a bit so I wouldn't bother with that. Also the bodywork isn't mint however I do have a new nearside wing that was bought but never fitted.
The radiator was replaced a couple of years back so that may be useful for someone???
You are welcome to come and remove bits yourself (in North Wales) or I can take smaller bits off and put them in the post. Please send me a pm if you are interested.
(I have a vague recollection of reading somewhere that the Xantia calipers will fit a BX; can anyone confirm whether this is true? I've already fitted 16v calipers on mine so no need to change.)
It's a dark blue, slightly metallic. I can probably have a look at the paint code if someone knows where it is? It is an LX model so it has a sunroof, front electric windows and cloth trim.
I'm 99% sure not as it is an early one; everything looks to be non-electronic on the engine, nice n' simple! Will check and let you know but probably not until Wednesday.
Cant say I need or want anything for a Xantia at all.
But I feel the need to recomend you as BXer of the year for breaking a Xantia! Stunning work fella!
docchevron1472 wrote:Cant say I need or want anything for a Xantia at all.
