Thought i would change the air filter (mines the rectangular shaped one) on the TZD, very dirty & wth a pool of oil at the front of the filter where the pipe from the intercooler connects upto.
So i checked all the other pipes that feed off the air box, including the large one near the rad, going as far as the one that sits above the cambelt.
They were all caked in oil (the inside), cleaned them all & put them back.
Should i be worried about all this oil? not being a mechanic, i dont understand how oil can enter through all these pipes & actually reach as far as the air filter. I can understand perhaps the intercooler pipe because its much closer (still dont understand why oil would be going into this pipe though).
I had to clean the air box, as it was plastered in oily crud. Took me hours to take everything apart, clean it & then re-fit it.
I took the intercooler off to check the rocker cover gasket wasnt leaking, seemed fine. Does anyone know where i can get hold of the small gasket which is at the far right hand side at the back which the intercooler is?
When i was up at Ken's, we took all this off before, & i noticed that the intercooler gasket was damaged, so did a temporary repair & put it back, but i want to replace it as i think the seal isnt 100 perfect.
To top all of that mularkey off, there is a banging sound at the rear of the car whenever i go over bumps, i've had a look but cant tell what it is & the rear arm bearings seem to be worse, so not driving her anymore untl i can get some help
So its back to using the gas guzzler to work & back
