when i tried to slacken the timing belt tensioner is was stuck fast and would move
After an hour of poking about I ran out of patience
Nothing !! It only moves about a half an inch but it can’t be moved back
What now ?
with a little heat (boiling water from a kettle) it shot out with a bangRichardW wrote: The (some heat should do it - just make sure you are not stood in the way in case the spring fires the piston out)
