High idle speed
fourwheelsteer
High idle speed
Post by fourwheelsteer »
I've got a BX 1.9 petrol automatic which even once it has warmed up idles at about 1500-2000rpm. The carb has been rebuilt earlier this year following a spate of poor running caused by 19 years build up of rubbish in the carb. As far as I can tell the auto choke is working correctly and the throttle cable is adjusted correctly. Is there any way to adjust the tickover speed to something more sensible?
Thanks in advance.
2008 Proton Gen2 EcoLogic
1998 Honda Prelude 2.2VTi
Now BX-less...
On my way to becoming a motoring writer.
My Blog: http://fourwheelsteer.blogspot.com/
mnde
Meteor Man
Post by mnde »
Hi,
Check out this document which should tell you how to adjust the idle speed and what the factory spec speed should be for your model.
http://www.rwbsmith.plus.com/citroen2/Carburation/
Cheers,
Mark.
