16V hp pump wanted
thanuttiscotsman
16V hp pump wanted
Post by thanuttiscotsman »
hey folks,
as described im after a hp pump for one of my valvers. must be the type that the pressure pipe comes out of the pump in the direction toward the front of the car not toward the block.
cheers rossco
1996 transit 2.5di 80 swb
Whats the RP number mate?
All valver pumps have the HP pipe coming out towards the front but the pump type changed at RP 4223.
thanuttiscotsman
hi there,
sorry for delayed reply been workin loads. anyhoo, basically im not sure of the number but do know i need a pump that the thinner pressure pipe heads in direction of front of car not toward the block. the pump is the same one on my ph1 89' as my ph2 90'. do you have one?
cheers rossco
Cant say I do, but I might know a man that does!
Or at least I know a man that a few a while ago, I suspect he still does.
But I know they were all for the earlier cars. IE up to 4223.
I dont know if they are interchangable, but I do know they are different.
All valver pumps look the same, but I believe the pulley's are different and more than likely the innards too...?
