Checking levels at the weekend I noticed that LHM was really low. Turned the engine on and got up to full height, when I saw a steady drip from the pressure regulator and from around the accumulator - the accumulator seemed to be leaking from the joint into the reg.
Well, after cleaning the area up and getting a bright light on it, it seems that the FDV has started leaking from all five pipes! This is a little odd, imho, and I wonder whether anyone else has experienced this. I tightened 4 of the 5 pipes up, getting between 1/3 to 1/2 of a turn out of each. That seems to have stopped it.
The leak from the accumulator may either be an actual leak from the accumulator, or just a collection of drips from the FDV, I haven't had time to properly investigate. Is it likely that the seal has failed?
Thanks
Oscar
FDV leak
- Our Trim Guru
