HEATER RESISTOR
tim leech
HEATER RESISTOR
Post by tim leech »
Post by ken newbold »
Worth the money me thinks :)
m_2975
My Cars: 1989 BX 19TRI Estate
1993 BX GTI
1997 Xantia CT Turbo
Post by m_2975 »
Yes, worth the money but seriously, when's the last time you needed one. If it goes bung you get a new resistor from an electronics shop and solder it on.
Michael
My Cars:
'93 BX 19GTi Sedan 5M
'89 BX 19TRI Estate 5M
'89 AX GT(With EFI) 2door 5M
In the Family:
'74 SM IE (Fully Restored) 5M
'90 BX 19TRI122 Sedan 4A
'06 C5 2.2HDi Estate 6A
tim leech
Post by tim leech »
The fanon my 16v is either on or off so maybe worth having?
kermit the frog
Post by kermit the frog »
Tim
Check out the heater mod on the forum.
My fan was on or off turned out to be a crack in the track on the circiut board. ( get a tiny strand of copper wire and a soldering iron and solder lay the tinned copper wire in the crack and flow solder over it scrape away excess to give a smooth surface for the wiper to run on and HEY it works)
do the mod while your in there. its great you wont believe the air flow.
tim leech
Post by tim leech »
The prob is kermit im mechanically backward!
In that case, put yourself in reverse, then you'll be mechanically forward...
tim leech
Post by tim leech »
Good thinking batman.
