Xantia Headlights
MikeT
Xantia Headlights
I've just checked the headlight specification and it reads both dipped and full beam are H1 55W's which I find inefficient.
All sensible tried and tested suggestions for improving night time visibility welcome.
Xantiaman
Philips Brilliance bulbs, still standard rating, are much brighter with a better beam than the original bulbs, i got some off ebay for not much more than the price of standard H1's, i still use normal H1's for the main beam but with the uprated dipped beam, dont find any problems.
Xantia ActivaLX - Fuelled by SVO
CitroXim
- Sir Jim of the Databases
I second the Philips bulbs Mike, an excellent choice.
That bulb you had from my stash was, in fact, out of my TD and did a fair impression of a glow worm. Sorry
Rewiring the headlights via relays and heavy-duty wiring direct from the high current distribution bar is a good idea. The standard wiring is awfully thin for the current it is expected to handle.
Jim
MikeT
CitroXim
100W bulbs are both illegal and WILL cook the standard wiring Mike, and possibly melt the lamps themselvesMikeT wrote: Would it be possible to fit 100w's to full beam or will I risk overloading?
Go the Philips route, they'll not annoy others and the difference will surprise you. The beam pattern will improve.
Rather that 100W jobs, you'd be better off going down the HID road but you know my views on those
On a related topic, I was delighted to see the MK II headlamps still produce the famous MK I "circle" when just sidelights are on. It is not quite so well defined as on a MK I though
Jim
MikeT
RichardW
Things have moved on... Phillips now do a +80% bulb, and Osram a +90% 'Nightbreaker'. Now, the lights in my MK11 are better than the Mk1, with normal bulbs, but not as good as with Phillips Vision plus (+50%). Was going to buy some Phillips +80%, but not available in H1 fitting, so ordered a pair of the night breakers. They are truly outstanding!! Almost as much light as my mate's Primera's HDi lamps. A vast improvement in night driving. No one has flashed coming the other way, and you can really see the sharp cut off much vaunted of the complex surface reflectors, and a really good kick-up along the kerb. Might fit some relays too to get every last bit....
I NEED a BX TD.
Baldbazza
For what it's worth, I'm running the Philips Vision plus (+50%) in the Alfa, and they're excellent.
Although from what I remember of my old Xantia's headlights (which wasn't much from behind the steering wheel at night), maybe a candle would double the lighting capacity?
And if you lit it, even better!
1985 BX 19 GT
2007 Alfa Romeo GT
2007 Alfa Romeo GT
CitroXim
Baldbazza wrote:And if you lit it, even better!
Jim
Xantiaman
Stewart (oily!)
cpt_spalding
MikeT
tim leech
Ive bought 2 new headlamps for my MK1 as the reflectors are very worn, and the glass is aged, however we had this car brand new and the headlamps were rubbish then, whatsthe best and most affordable direct replacement for the standard bulbs without spending a small fortune.
Does anyone have a link for them?
Ta
Ta
