Xantia HDi 110 F Brakes
post here until we fix the rest of your forum
Locked
RichardW
Post by RichardW »
Anybody know the min thickness for the front discs on the HDi 110? Not covered in my BOL....
Also, how do you change the pads? I presume you undo the inviting looking bolt on the bottom inside of the caliper and pivot up in the same way as the 'lesser' cars - but I don't really want it just to go 'ping' and scatter parts to the 4 winds if that is not the way to go in :roll:
I NEED a BX TD.
Clogzz
Contact:
Post by Clogzz »
2002 C5 2.0i AL4 207,000 km 76372389
Dickieg
Post by Dickieg »
Just remove the lower bolt and the caliper swings upwards, make sure you wind the piston back in.
Locked
