How do I get them off? I need to clean the clogged drains from the sunroof and for that I follow a guide at the BX DIY page (Water from the sunroof). I need to remove all the covers and panels to remove the roof, but I can't remove the C pillar trim panels. They are held in place by those annoying plastic "nails". I can make them loose, but the last part won't come off. I tried using force but I don't want to break it in the end. It seems like its possible to slide the whole panel forward because the hooks on the panel are open on the rear side but I can't get it off. Has anyone removed these things before?
Thanks
