Coolant Bleed Points
Ian_Fearn
Post by Ian_Fearn »
According to Haynes theres only 2 bleeds points on the TD engine. 1 on the rad and 1 on the thermostat housing. Is this correct?
Over and out from me
AndersDK
Post by AndersDK »
Not seen any other on mine.
With cold engine top up ccolant and bleed at the 2 points until coolant starts flowing out. Note that the coolant must be at top level on radiator, while expansion tank should be 1/2 level at cold.
Ian_Fearn
Post by Ian_Fearn »
Thanks
