I've been suffering with clogged fuel filters (i didnt know why) & the car has been down on power, fuel economy & will cut out on a regular basis. Its recently gotten terrible.
So i had the tank drained, however the mechanic couldnt access the tank from underneath the rear seats as he couldnt find the hole??? he reckons there isnt one there? i thought all BX's had a sender unit of some description residing there?
Anyway, so he drained it from the other end of the tank (not the best way apparently), he reckons there is still a bit in (how much, dont know???). So i plonked in 10 fresh litres to mix up with whatever is in there to hopefully pick up any crap to further clean out the tank.
However, the car drove exactly the same, flat out 40mph, occasionaly reaching 50mph, on off surging, but would eventually slow down & the engine would then cut out...
Mechanic said he checked the fuel filter & it was ok?? i will check it tomorrow.
Is there anything i can do to get the car running again? at the mo its scrap material as i cant drive it anywhere without being a mobile chicane....
I also went to the bio-diesel garage to find out about the fuel that i had dropped off last week that i thought may be contaminated & had been causing problems with my car...
They confirmed it was a bad batch of fuel & said that they would replace the fuel...
However, its cost me so far 1 fuel filter & £25 to drain the tank, plus i still cant drive the sodding thing, what can i do from a legal standpoint, basically i want the bio-diesel place to pay to fix my car as it was their fuel which has fucked things up right & proper.
You'll have to excuse my tone & language, i'm extremely pissed off about this....
